Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Custom scripting
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Kiwi CatTools provides a custom scripting facility to add your own custom devices and activities to the user interface. Custom scripting is beneficial should your device not be supported by one of the pre-defined device types, or the supplied activities not meet your specific requirements.
Detailed information on custom scripting, such as how to create the custom files, location of the custom scripting templates, code examples, and so on, can be found in:
When adding custom devices, activities, or reports to CatTools, you need to edit the script files using a script editor.
