Manage Azure Virtual Networks in IPAM
IPAM integration with Azure Virtual Network (VNet) enables you to view both on-premises and Azure cloud virtual networks and their subnets and virtual machines (VM) with the IPAM interface. You must have a SAM, VMAN, or SolarWinds Observability Self-Hosted Advanced license to use this functionality.
VNets are visible under Manage Subnets & IPs after your Azure Cloud account is added and data polling is complete. If you have not added your Azure Cloud, see Add another cloud account.
Go to Settings > All Settings > Manage Subnets & IPs.
Expand Virtual Networks. Your networks are listed in the left pane.
You can also click Virtual Networks to view a complete list of all your virtual networks in the right pane. -
In the left pane, expand a VNet and click a subnet. Your virtual machines for the selected VNet are listed in the right pane.
Hover over a virtual machine name to see specific details about that virtual machine, such as its state, location, and the subnet name.
Click a virtual machine name to open the Azure Cloud VM details, where you can manage the VM (start/stop, reboot, delete, etc.).
To search within the selected element, use the Filter button or the Search within selected element field at the top of the details table.
The Advanced Search option at the top can be used to search for specific elements, such as VNet virtual IP Addresses or VNet subnet addresses across all available data.
To view AWS VPCs in IPAM, see Manage AWS VPCs in IPAM.
