Documentation forSecurity Event Manager
SEM 2026.4 System Requirements
Release date: October 20, 2026
SolarWinds strongly recommends that you install Security Event Manager on a server that is neither public, nor internet-facing. To learn about best practices for configuring your Security Event Manager installation securely, see Best practices to secure SolarWinds Products.
These system requirements will help you plan your Security Event Manager (SEM) deployment for your specific network environment.
Server sizing
Server sizing is impacted by:
  • Number of nodes
  • Network traffic
  • Storing original (raw) and normalized log messages
Consider event throughput and performance degradation when planning the size of your deployment. As the number of nodes and network traffic increase, the size of your deployment will need to grow as well. For example, if you are running a small deployment and begin to notice performance degradation at 300 nodes, move to a medium deployment.
If you will be storing original log messages, increase the CPU and memory resource requirements by 50 percent. See your hypervisor documentation for more information.
Sizing criteria
Use the following table to determine if a small, medium, or large deployment is best suited to supporting your environment.
These requirements also apply to the SEM FIPS manager application.
Sizing Criteria Small Medium Large
Number of nodes
Fewer than 500 nodes in the following combinations:
  • 5 – 10 security devices
  • 10 – 250 network devices, including workstations
  • 30–150 servers
Between 300 and 2,000 nodes in the following combinations:
  • 10 – 25 security devices
  • 200 – 1,000 network devices, including workstations
  • 50 – 500 servers
More than 1,000 nodes in the following combinations:
  • 25 – 50 security devices
  • 250 – 1,000 network devices, including workstations
  • 500 – 1,000 servers
Events received per day 216M – 432M events 432M – 648M events
Up to 864M events (10,000 EPS)
Rules fired per day Up to 500 Up to 1,000 Up to 5,000
SEM VM hardware requirements
See Allocate CPU and memory resources to the SEM VM in the SEM Product Guide for information about how to manage SEM system resources.
Hardware on the VM host Small Medium Large
CPU
2 – 4 core processors at 2.0 GHz
6 – 10 core processors at 2.0 GHz
10 – 16 core processors at 2.0 GHz
If you will be storing original log messages in addition to normalized log messages, increase the CPU and memory resource requirements by 50%.
EPS Range 2500 to 5000 5000 to 7500 7500 to 10000
Memory 8 GB RAM 16 GB – 48 GB RAM 48 GB – 256 GB RAM
Hard drive storage 250 GB, 15k hard drives (RAID 1/mirrored settings) 500 GB, 15K hard drives (RAID 1/mirrored settings)
1TB, 15k hard drives (RAID 1/mirrored settings)
  • Installing SEM in a SAN is preferred.
  • High-speed hard drives (such as SSD drives) are required for high-end deployments.
  • Large deployments may require 1 to 2TB of storage, which you can reserve on VMware ESXi 6.0 (and later) and Microsoft Hyper-V 2012 R2 or 2016.
Input/output operations per second (IOPS) 40 – 200 IOPS 200 – 400 IOPS 400 or more IOPS
NIC 1 GBE NIC 1 GBE NIC 1 GBE NIC
SEM Azure hardware requirements
Small
(Standard_DS3_v2)
Medium
(Standard_DS4_v2)
Large
(Standard_D32s_v3)
CPU [cores]
4
8
32
RAM [GB] 14 28 128
IOPs 12800 25600 51200
SEM Google Cloud Platform (GCP) hardware requirements
Size
Small
Medium
Large
CPU
2-4 cores
6-10 cores
10-16 cores
RAM
8-16 GB
16-48 GB
48-256 GB
Disk 250 GB, 40 – 200 IOPS 250-500 GB storage, 200 – 400 IOPS 1 TB storage, 400 or more IOPS
Nodes (security devices, network devices/workstations, servers)
< 500 (5-10, 10-250, 30-150)
300 - 2000 (10-25, 200-1000, 50-500
> 1000 (25-50, 250-1000, 500-1000)
Events per day 5M – 35M 30M – 100M 100M+
NIC NIC: 1 GBE NIC: 1 GBE NIC: 1 GBE
GCP suggested equivalent machine type
  • n2-standard-2 (2 vCPU, 8 GB RAM)
    • Lower cost alternative: e2-standard-2
  • n2-standard-4 (4 vCPU, 16 GB RAM)
    • Lower cost alternative: e2-standard-4
  • n2-standard-8 (8 vCPU, 32 GB RAM)
  • n2-highmem-16 (16 vCPU, 128 GB RAM), with options to scale RAM to 256 GB
GCP suggested equivalent storage
  • Balanced Persistent SSD (pd-balanced), 250 GB
    • Lower cost alternative: Standard Persistent Disk (pd-standard), 250 GB
  • Balanced Persistent SSD (pd-balanced), 500 GB
  • Balanced Persistent SSD (pd-balanced), 1 TB
GCP suggested equivalent network (if using external IP)
  • Standard Tier VPC (this setup is ideal for small log volumes and environments with limited devices or systems to monitor)
  • Standard Tier VPC, optionally upgradeable for additional performance (appropriate for medium-sized networks with moderate event rates and log generation)
  • Premium Tier VPC for high-traffic, globally distributed systems (large deployments are suitable for enterprise-scale networks with high event volumes and complex log processing)
Additional сonsiderations
  • Storing Raw Logs: if you store original logs in addition to normalized logs, increase CPU and RAM requirements by 50% across all deployment sizes
  • Balanced SSD vs. Standard HDD: use Balanced Persistent SSD in medium and large deployments for better IOPS and reduced latency
  • Network Tier (if using external IP): for large-scale deployments or globally distributed environments, Premium Tier network might be required for lower latency and better performance
  • Scaling: use custom machine type settings (select vCPUs and RAM) to scale your deployment based on your needs
SEM AWS hardware requirements
Instance size
m5.xlarge / m5a.xlarge
m5.2xlarge / m5a.2xlarge
m5.8xlarge / m5a.8xlarge
vCPU
4 8 16
Memory (GiB) 16 32 128
Instance Storage EBS-Only EBS-Only EBS-Only
SEM FIPS edition on Red Hat Enterprise Linux requirements
Starting with SEM 2026.4, you can install the FIPS edition of SEM on a Red Hat Enterprise Linux (RHEL) server that runs in FIPS mode.
Component Requirements
Operating system
Red Hat Enterprise Linux 9.8 (x86_64) with the following configuration:
  • FIPS mode enabled
  • System registered with Red Hat
  • BaseOS and AppStream repositories enabled
Hardware
Same as the virtual appliance sizing. See Sizing criteria and SEM VM hardware requirements.
Ports
Open the following ports in the RHEL firewall:
  • 443, 8443, 80, 8080 TCP: web console and API
  • 37890–37892 TCP: SEM agents
  • (Optional) 514 TCP/UDP: syslog
  • (Optional) 161, 162 UDP: SNMP
See SEM port requirements for details.
Time synchronization Time synchronization configured with chronyd.
Name resolution A fully qualified domain name (FQDN) for the server that resolves in DNS.
SEM software requirements
Software Requirements
Hypervisor (required on the VM host)
One of the following:
  • VMware vSphere ESXi 6.0 or ESXi 6.0 and later
  • Microsoft Hyper-V Server 2012 R2, 2016, and 2019
Microsoft Azure Learn about Microsoft Azure requirements here.
Amazon Web Services Learn about Amazon Web Services requirements here.
Red Hat Enterprise Linux (FIPS edition) Red Hat Enterprise Linux 9.8 (x86_64) in FIPS mode. See SEM FIPS edition on Red Hat Enterprise Linux requirements.
IP networking
SEM supports IPv4-only and dual-stack (IPv4 and IPv6) networking.
Web browser
  • Google Chrome 120 or newer
  • Mozilla Firefox 120 or newer
  • Microsoft Edge v120 or newer
SEM agent hardware and software requirements
Hardware and Software Requirements
Operating System (OS)
The SEM agent is compatible with the following operating systems:
  • HPUX on Itanium
  • IBM AIX 7.1 TL3, 7.2 TL1 and later
  • Linux
  • Oracle Solaris 10 and later
  • Windows 10, 11
  • Windows Server 2012, 2016, 2019, 2022, and 2025
    Windows Server 2025 supports SEM 2026.2 and later.
The following requirements are the minimum requirements. Depending on your deployment, you may need additional resources to support increased log-traffic volume and data retention.
Memory 512 MB RAM
Hard Drive Space 1 GB
Other requirements
Administrative access to the device hosting the SEM Agent.
The SEM agent for AIX requires Java Runtime Environment (JRE) 25 or later.
The SEM agent for HP-UX requires Java Runtime Environment (JRE) 25 or later.
The SEM agent for Solaris requires Java Runtime Environment (JRE) 25 .
For a list of ports required to communicate with SolarWinds products, see SolarWinds Port Requirements.
Port # Protocol Service/Process Direction Description
22 TCP SSH Bidirectional SSH traffic to the SolarWinds SEM VM. If you need to close ports 22, contact SolarWinds Support.
25 TCP SMTP Outbound SMTP traffic from the SolarWinds SEM VM to your email server for automated email notifications.
80, 8080 TCP HTTP Bidirectional
Non-secure HTTP traffic from the SolarWinds SEM console to the SolarWinds SEM VM. (SEM closes this port when the activation is complete.)
445 TCP NetBIOS, SMB2 Bidirectional
Standard Windows file sharing ports (NetBIOS Session Service, Microsoft SMB) that SEM uses to export debug files, syslog messages, and backup files.
The SEM Remote Agent Installer also uses these ports to install agents on Microsoft Windows hosts across your network.
Server Message Block version 1 (SMB1) is no longer supported.
161, 162 TCP SNMP Bidirectional SNMP trap traffic received from devices, and used by the Orion platform to monitor SEM.
389, 636 TCP  LDAP Outbound
LDAP ports that the SEM Directory Service Connector tool uses to communicate with a designated Active Directory domain controller.
The SEM Directory Service Connector tool uses port 636 for SSL communications to a designated Active Directory domain controller.
443, 8443 TCP HTTPS Bidirectional
HTTPS traffic from the SolarWinds SEM console to the SEM VM.
SEM uses these secure HTTP ports after SEM is activated.
This port is also used to automatically update the SEM Connectors.
514 TCP or UDP Syslog Inbound Syslog traffic from devices sending syslog event messages to the SolarWinds SEM VM.
(636) TCP     See entry for port 389.
1094 TCP Syslog Inbound Syslog traffic from certain Cisco devices.
1470 TCP PSyslog Inbound Syslog traffic from certain Cisco devices.
(8080) TCP     See entry for port 80.
(8443) TCP     See entry for port 443.
8983 TCP nDepth Inbound nDepth traffic sent from nDepth to the SEM VM containing raw (original) log data.
37890-37892 TCP SEM Agents Bidirectional SEM Agent traffic sent from SolarWinds SEM Agents to the SolarWinds SEM VM. (These ports correspond to the destination ports on the SEM VM.)
49671 TCP Registry Inbound Required to install the USB Defender service on a Windows remote agent.
