SEM 2019.4 system requirements
March 26, 2020
SolarWinds strongly recommends that you install Security Event Manager on a server that is neither public, nor internet-facing. To learn about best practices for configuring your Security Event Manager installation securely, see Best practices to secure SolarWinds Products.
Use the following tables to plan your Security Event Manager (SEM) deployment to suit your network environment.
Server sizing is impacted by:
- Number of nodes and network traffic. Consider event throughput and performance degradation when planning the size of your deployment. As the number of nodes and network traffic increase, the size of your deployment will need to grow with it. For example, if you are running a small deployment and begin to notice performance degradation at 300 nodes, move to a medium deployment.
- Storing original (raw) log messages in addition to normalized log messages. If you will be storing original log messages, increase the CPU and memory resource requirements by 50 percent. See your hypervisor documentation for more information.
Sizing criteria
Use the following table to determine if a small, medium, or large deployment is best suited to supporting your environment.
Sizing Criteria | Small | Medium | Large |
Number of nodes |
Fewer than 500 nodes in the following combinations:
Between 300 and 2,000 nodes in the following combinations:
More than 1,000 nodes in the following combinations:
Events received per day | 5M – 35M events | 30M – 100M events |
Up to 215m events (2,500 EPS) |
Rules fired per day | Up to 500 | Up to 1,000 | Up to 5,000 |
SEM VM hardware requirements
See Allocate CPU and memory resources to the SEM VM in the SEM Administrator Guide for information about how to manage SEM system resources.
Hardware on the VM host | Small | Medium | Large |
CPU |
2 – 4 core processors at 2.0 GHz |
6 – 10 core processors at 2.0 GHz |
10 – 16 core processors at 2.0 GHz |
If you will be storing original log messages in addition to normalized log messages, increase the CPU and memory resource requirements by 50%. |
Memory | 8 GB RAM | 16 GB – 48 GB RAM | 48 GB – 256 GB RAM |
Hard drive storage | 250GB, 15k hard drives (RAID 1/mirrored settings) | 500GB, 15K hard drives (RAID 1/mirrored settings) |
1TB, 15k hard drives (RAID 1/mirrored settings) |
Input/output operations per second (IOPS) | 40 – 200 IOPS | 200 – 400 IOPS | 400 or more IOPS |
NIC | 1 GBE NIC | 1 GBE NIC | 1 GBE NIC |
SEM Azure hardware requirements
Small Standard_DS3_v2 |
Medium Standard_DS4_v2 |
Large Standard_D32s_v3 |
CPU [cores] |
4 |
8 |
32 |
RAM [GB] | 14 | 28 | 128 |
IOPs | 12800 | 25600 | 51200 |
SEM software requirements
Software | Requirements |
Hypervisor (required on the VM host) |
One of the following:
Microsoft Azure | Learn about Microsoft Azure requirements here. |
Amazon Web Services | Learn about Amazon Web Services requirements here. |
Web browser (required on a remote computer to run the web console) |
Current and later versions of the following:
Adobe Flash (browser plug-in required on a remote computer to run the web console) | Adobe Flash Player 15 |
SEM agent hardware and software requirements
Hardware and Software | Requirements |
Operation System (OS) |
The SEM agent is compatible with the following operating systems:
The requirements specified below are minimum requirements. Depending on your deployment, you may need additional resources to support increased log-traffic volume and data retention. |
Memory | 512 MB RAM |
Hard Drive Space | 1 GB |
Other requirements |
Administrative access to the device hosting the SEM Agent. The SEM agent for Mac OS X requires Java Runtime Environment (JRE) 8 or later. |
SEM reports application hardware and software requirements
The SEM reports application is Windows only. The following Windows versions are supported:
Memory |
512 MB RAM minimum. SolarWinds recommends using a computer with 1 GB of RAM or more for optimal reports performance. |
Install the SEM reports application on a system that runs overnight. This is important because the daily and weekly start time for these reports is 1:00 AM and 3:00 AM, respectively. Ensure the Reports Console version matches your version of the SEM appliance. Incompatible versions may result in installation or login failures.
See the following articles in the Customer Success Center for troubleshooting tips: |
SEM port requirements
If your logs are located behind firewalls, see SolarWinds SEM port and firewall requirements.
For a list of ports required to communicate with SolarWinds products, see Port requirements for all SolarWinds products.
