Start Network Atlas for the SolarWinds Platform
EOC — NAM — NCM — NPM — NTA — SAM — SRM — UDT — VMAN — VNQM
Network Atlas is deprecated. SolarWinds recommends that you start using Intelligent Maps in the SolarWinds Platform Web Console to display maps of physical and logical relationships between entities monitored by the SolarWinds Platform products you have installed.
Additionally, you can import Network Atlas maps to Intelligent Maps.
Users must have the Map Management right in SolarWinds NPM or in Orion EOC.
  1. Log in to the computer hosting your Network Atlas installation.
  2. Start Network Atlas in the SolarWinds program folder.
  3. Connect to your primary SolarWinds Platform server:
    1. Provide your SolarWinds Platform Web Console user name and password.
    2. Provide the IP address or hostname of your primary SolarWinds Platform server in the Address field.
    3. If you are connecting to an SolarWinds NPM server, select Orion as the Connect To target.
    4. If you are connecting to an Orion EOC server, select EOC as the Connect To target.
    5. Click Connect.
  4. Now on the Network Atlas Welcome screen, select what map you want to open:
