Charts and graphs
This topic applies to all SolarWinds Platform products.
The following charts and graphs are available in views. Not all views are available to all products, and some charts are not present in the default view.
As of Orion Platform 2018.4, SolarWinds Platform deprecates certain versions of charts: legacy and classic/historical charts are being deprecated. If you are upgrading from a previous SolarWinds Platform version and are using these charts, they will be retained in your SolarWinds Platform Web Console.
SolarWinds recommends that you switch from the deprecated charts to the modern charts to avoid data loss in a future SolarWinds Platform version.
- Availability Chart
- Availability AutoScale Chart
- Availability and Response Time Chart
- Average Bits per Second Chart
- Average CPU Load Chart (available as a modern chart)
- Average Disk Space Used Chart (available as a modern chart)
- Average Memory Usage Chart (available as a modern chart)
- Average Response Time Chart
- Average Response Time and Packet Loss Chart
- Custom Network Wide Chart
- Custom Node Charts
- Custom Volume/Disk Chart
- Min/Max/Average CPU Load Chart (available as a modern chart)
- Min/Max/Average Memory Usage Chart (available as a modern chart)
- Min/Max/Average Response Time Chart
- Min/Max/Average Response Time and Packet Loss Chart
- Network Latency and Packet Loss Chart (available as a modern chart)
- Network Wide Availability Chart
- Network Wide Availability and Response Time Chart
- Network Wide Frame Relay Utilization Chart
- Network Wide Average Response Time Chart
- Network Wide Min/Max/Average Response Time Chart
- Percent Disk Space Used Chart (available as a modern chart)
- Percent Loss - Bar Chart
- Percent Loss - Line Chart
- Percent Memory Used Chart
- Virtual Machine Memory Consumption Area Chart
