Manage Quality of Experience applications
NAM — NPM
The Manage Quality of Experience (QoE) Applications page is where you add new applications and modify existing applications so you can capture and analyze packet-level data.
The following information describes the columns.
Application Name: The name of the application.
Monitoring: If the application is Enabled, it can be analyzed and traffic of this application type is monitored.
Discovery: If you have auto-discovery enabled in the Global QoE Settings page, then this setting enabled sensors to automatically monitor traffic from this application.
Category: The classification of the application. To change the category, follow the instructions in Add or edit Quality of Experience applications.
Risk Level: The classification of the risk level as determined by the person who entered the application. To change the risk level, follow the instructions in Add or edit Quality of Experience applications.
Productivity Rating: The general definition of the application's use. To change the productivity rating, follow the instructions in Add or edit Quality of Experience applications.
Sensors Collecting Data: The number of nodes collecting data for this application.
Last Discovered Date: Traffic associated with this application was last discovered on the date displayed.
Last Discovered On: Traffic associated with this application was last discovered on the displayed node.
