Custom Properties for Volumes
DPAIM — EOC — IPAM — LA — NAM — NCM — NPM — NTA — SAM — SRM — UDT — VMAN — VNQM
This widget provides a list of custom properties defined for the selected volume.
Select properties
Click Edit, and select the custom properties to display.
If no custom properties are available, define them in the Custom Property Editor.
Edit custom property values
Selected custom properties are displayed only if the volume has a value specified for them. If the selected custom property is not specified for the volume, it does not appear in the widget.
To add or edit a property value for the node, click Edit Custom Property Values, and edit the volume properties.
