Unique Visitors
This widget provides a chart reporting the number of unique IP addresses that have communicated over the network during a specified period of time.
When placed on the Node Details or Interface Details view, the widget provides a chart reporting the number of unique IP addresses that have communicated with the viewed node or interface.
A custom endpoint-centric version of this widget, called Unique Visitors (Endpoint Centric), can also be placed on the NetFlow Node Details or Interface Details view, providing a view of the unique IP addresses with which the viewed node or interface has communicated during the selected period of time. For more information about adding endpoint-centric widgets, see Add endpoint-centric widgets to NTA views.
Widgets in the SolarWinds Platform Web Console are edited on the Edit Resource page. The options available depend on individual widgets.
If you are logged in using a User ID with administrative privileges, you can change the way a widget is displayed for all users.
- Click Edit in the header of the widget.
- Customize the available options:
- Title.
- Subtitle.
- Maximum Number of Items to Display.
- Chart customization options. For more information, see Customize charts for all users in NTA.
- Click Submit.
