Universal Device Poller - Label Table Values
When your defined Universal Device Poller is used to poll a MIB table, specify the table labels which will display on any SolarWinds Platform Web Console resources, including reports and charts.
Use interface names from Orion
This option applies the labels from the interface table of the polled node to the poller results table.
Use labels from a table column
Select the column title you want to use as the label for your poller results table.
SolarWinds recommends this option because it enables you to maintain a clear and direct connection between the polled table and the results table.
Use a custom label
Simply type your custom label in the Label field.
When you have selected the labels for your poller results table, click Next or Finish to continue.
