Universal Device Poller - Define Transform
  1. Type a name and a description for the transformation, and click Next. Names must be unique.
    Names are required. Any spaces in the name are removed.
    Descriptions are optional but might be helpful in identifying the type of information generated by the transformation.
  2. You can also change other default settings:
    1. Select Yes in the Keep Historical Data section. You will be able to view the transformed poller data in charts and gauges in the SolarWinds Platform Web Console.
    2. Select Enabled as the Status if you want your transformation to begin calculating results immediately.
      If you select Disabled, the transformation will not transform polled data.
    3. In the Group field, select a group where you want to add the transformation. To add a group, provide the new group name.
    4. Optional: Provide a polling interval.
      Make sure all pollers in the transformation use the same polling interval.
