Universal Device Poller - Assign Poller to Nodes
Select an option in the Group By field to organize the node list, so that it is easy to navigate to monitored nodes.
  1. Expand the node tree down to the interface level, if necessary, and select the elements to which you want to apply the pollers.
    • Interfaces are not displayed unless you are assigning an interface poller.
    • Selecting a node automatically assigns a selected interface poller to all interfaces on the node. Clear boxes for the interfaces to which the poller should not be assigned.
  2. Click Test to see current results of the selected pollers on the selected nodes or interfaces.
  3. For pollers polling a table, the Test Results display as a comma‑delimited list of values for each tested node. These values are taken from a column, and are represented horizontally.
  4. Complete your poller assignments, and click Finish.
