SolarWinds Platform Web Console widgets
You can include the following widgets into SolarWinds Platform Web Console views.
Some widgets are relevant for summary views, other widgets can be used only on details views for a certain technology.
Cannot see a widget?
  • Make sure it is relevant for the view.
  • Make sure it is supported for the device technology.
  • Make sure the data for the widget is polled. If the data is not available and the widget is set to Auto-Hide, you will not see it on the view.
If you have verified all the above items, add it.
You can also customize the widget.
