Node Utilization by Multicast
This resource provides an overview of the node utilization by multicast traffic.
Customize the chart
Click Edit, specify what the chart should display, and click Submit.
Specify the default time interval shown by the chart
Select a time interval in the Default Zoom Range list to define the overall time window for your chart. You can zoom in to shorter time periods.
Specify the time interval used for calculating what items will be displayed
In Amount of Historical Data to Load, select the time interval used for calculating the displayed items.
If there was a peak in data two weeks ago, you will not see it on the chart when a shorter time period, such as Past Week or Past 24 hours is selected.
Specify what a single point in the chart stands for
In Sample Interval, select a frequency. Data collected during the specified interval will be summarized and displayed as a single point or bar in the in the chart.
Add chart labels
Click Advanced and insert text or variables displayed as the title and subtitle for the chart.
