Interface Properties
The following interface properties, listed in variable format, are currently defined and available in NPM:
Interface Variable |
Description |
${AdminStatus} |
Numeric administrative status of interface. For more information, see "Node Status Variables" in the SolarWinds Network Performance Monitor Administrator Guide. |
${AdminStatusLED} |
Filename of current interface administrative status icon |
${AvgSignalNoise} |
Average signal to noise ratio, in 0.1db, over last polling interval |
${Caption} |
User friendly description of interface combining name with other identifying information |
${CodewordsCorrected} |
Total correctable codewords received on interface for all frames received |
${CodewordsUnCorrectable} |
Total uncorrectable codewords received on interface for all frames received |
${CodewordsUnerrored} |
Total unerrored codewords received on interface for all frames received |
${Counter64} |
States if interface supports IF-MIB high capacity counters |
${CustomBandwidth} |
Indicates if transmit and receive bandwidth fields are user‑controlled (1) or controlled by automated detection via ifSpeed MIB (0) |
${CustomPollerLastStatisticsPoll} |
Day, date, and time that this interface was last polled by the current Universal Device Poller |
${FullName} |
User friendly name combining captions of parent node and interface |
${IfName} |
Internal name discovered for this interface with the ifName OID |
${InterfaceID} |
Internal unique identifier of selected interface |
${InBandwidth} |
Incoming bandwidth of interface |
${Inbps} |
Current incoming traffic, in bps, to interface |
${InDiscardsThisHour} |
Number of incoming packets discarded by interface in last hour |
${InDiscardsToday} |
Number of incoming packets discarded by interface in current day |
${InErrorsThisHour} |
Number of interface receive errors in last hour |
${InErrorsToday} |
Number of interface receive errors in current day |
${InMcastPps} |
Current incoming multicast traffic, in packets per second, to interface |
${InPercentUtil} |
Current percent utilization of interface receive |
${InPktSize} |
Average size of incoming packets to interface |
${InPps} |
Current incoming traffic, in packets per second, to interface |
${InterfaceAlias} |
Alias or description of interface discovered from parent node |
${InterfaceIcon} |
Filename of the icon used to represent the interface type |
${InterfaceIndex} |
Index of selected interface on parent node |
${InterfaceLastChange} |
sysUpTime value when the interface entered current operational state |
${InterfaceMTU} |
Interface Maximum Transfer Unit: the largest packet the interface can handle |
${InterfaceName} |
User friendly name |
${InterfaceSpeed} |
Interface bandwidth |
${InterfaceType} |
IANA type of selected interface |
${InterfaceTypeDescription} |
User friendly description of interface type |
${InterfaceTypeName} |
User friendly name of interface IANA type |
${InUcastPps} |
Current incoming unicast traffic, in packets per second, to interface |
${LastSync} |
Time and date of last interface database and memory synchronization |
${MaxSignalNoise} |
Maximum signal to noise ratio, in 0.1db, over last polling interval |
${MinSignalNoise} |
Minimum signal to noise ratio, in 0.1db, over last polling interval |
${NextPoll} |
Day, date and time of next scheduled interface polling |
${NextRediscovery} |
Next interface rediscovery time |
${NodeID} |
Internal unique identifier of node that is parent to the selected interface |
${ObjectSubType} |
States if parent node supports SNMP or is ICMP only |
${OperStatusLED} |
Filename of current interface operational status icon |
${OutBandwidth} |
Outgoing bandwidth of interface |
${Outbps} |
Current outgoing traffic, in bps, from interface |
${OutDiscardsThisHour} |
Number of outgoing packets discarded by interface in last hour |
${OutDiscardsToday} |
Number of outgoing packets discarded by interface in current day |
${OutErrorsThisHour} |
Number of interface transmit errors in last hour |
${OutErrorsToday} |
Number of interface transmit errors in current day |
${OutMcastPps} |
Current outgoing multicast traffic, in packets per second, from interface |
${OutPercentUtil} |
Current percent utilization of interface transmit |
${OutPktSize} |
Average size of outgoing packets from interface |
${OutPps} |
Current outgoing traffic, in packets per second, from interface |
${OutUcastPps} |
Current outgoing unicast traffic, in packets per second, from interface |
${PercentCodewordsCorrected} |
Percent correctable codewords |
${PercentCodewordsUnCorrectable} |
Percent uncorrectable codewords |
${PercentCodewordsUnerrored} |
Percent unerrored codewords |
${PhysicalAddress} |
Physical address of interface |
${PollInterval} |
Interval, in seconds, between polling attempts for interface |
${RediscoveryInterval} |
Interval, in minutes, between rediscovery attempts for interface |
${Severity} |
A network health score providing 1 point for an interface in a warning state, 1000 points for a down interface, and 1 million points for a down node |
${SignalNoise} |
Signal to noise ratio, in 0.1db, for this channel. At CM, describes downstream signal to noise ratio. At CMTS, describes upstream signal to noise ratio |
${StatCollection} |
Interface statistics collection frequency, in minutes |
${Status} |
Numeric interface status. For more information, see "Node Status Variables" in the SolarWinds Network Performance Monitor Administrator Guide. |
${StatusLED} |
Filename of current interface status icon |
${TotalCodewords} |
Total codewords received on interface, regardless of error state, for all frames received |
