Connectivity Unit Status
The Connectivity Unit Status widget provides a quick report of the state of VSAN connectivity for the viewed node.
Statistic |
Description |
Name |
Name of the listed VSAN member node |
WWN |
World Wide Name, a unique identifier, of the listed VSAN member node |
Model Name |
Vendor-designated model number/name, as reported by the listed VSAN member node |
Serial # |
Vendor-designated device serial number, as reported by the listed VSAN member node |
CU Type |
Network device type (Connectifity Unit Type), as reported by the listed VSAN member node |
Revision ID and Description |
Vendor-designated device revision identifier and description, as reported by the listed VSAN member node |
CU State |
Connectivity Unit State |
CU Status |
Connectivity Unit Status |
