Custom Properties for Nodes
This widget provides a list of custom properties defined for the selected node.
Select properties
Click Edit, and select the custom properties to display in the widget.
By default, you can select City, Department, and Comments properties. If you want different custom properties, define them.
Edit custom property values
Selected custom properties are displayed only if the node has a value specified for them. If the selected custom property is not specified for the node, it does not appear in the widget.
To add or edit a property value for the node, click Edit Custom Property Values, and edit the node properties.
