Build complex conditions in the SolarWinds Platform
Complex conditions are generally enabled by users who are comfortable with building normal trigger conditions, or who have trialed alerts using the normal trigger conditions and require more control over the trigger conditions to better refine the environmental conditions that trigger an alert.
Do not use complex conditions until you have tested the trigger conditions individually. Creating an alert with complex conditions without testing it may prevent you from receiving important alerts.
  1. Navigate to the Trigger Condition page.
  2. Expand Advanced options.
  3. Select Enable complex conditions.
You can use complex conditions to do the following:
