Documentation forLog Analyzer
Filter on log tags
In the LA Log Viewer Filters pane, you can filter on your pre-defined and custom color-coded log tags as the tagged events stream into the viewer. To filter event logs based on a specific tag, click to expand the Tags group in the Filters pane, and then select one or more tag check boxes.
