Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools API: Group class
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Group class encapsulates a CatTools device Group object. These values are presented in the Group drop list when you edit a device.
Properties
ID
The ID used to identify this Group in the database.
Name
The friendly name of the Group that you see on screen.
When CatTools starts it removes from the database any unlinked entries.
Add a group using the Group class
To add a new group simply assign it to a Devices.Group property.
Use the Groups class to enumerate Group objects and populate them into a drop list for your user to select from.
It is not possible to add, edit, or delete Groups using the Groups class.
