Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools API: Device class
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Device class is used encapsulates a Kiwi CatTools device.
Properties
AAAUsername / AAAPassword
The username and password to use if your device requires a username/password login.
AAAUserPrompt / AAAPassword Prompt
The prompt request for the username and/or password of your device.
ActivitySpecific1 / ActivitySpecific2
Not used
Address1 / Address2 / Address3
The location of the device.
AlertEmail
User to receive notifications by e-mail for any triggered alerts from this device.
AssetTag
Asset tag information.
ConnectionMethod
The method to use when connecting to this device.
  • For example: Telnet or SSH2.
ConnectVia
The name of the device to connect via.
ConnectViaID
The ID of the device to connect via.
  • An ID of -1 indicates a direct connection.
ConsolePassword
The console (com port connection) password.
ConsolePrompt
What does the console password request look like from your device.
ContactName / ContactEmail / ContactPhone / ContactOther
Contact information for the person responsible for a device.
EnablePassword
The password to get into enable mode.
EnablePrompt
What does the enable password request look like from your device.
EnableUsesAAA
Does entering enable mode require username/password validation?
FileName
The base file name for the device.
Group
The name of the Group the device belongs to.
For example: Default
GroupID
The id corresponding to the Group field. -1 indicates a new Group is to be created.
HostAddress
The IP address or host address for this device.
ID
The id that identifies this device in the database.
Identification
Identification info for this device.
LoginUsesAAA
Does connecting to the device require username/password validation?
Model
A value describing the model of the device.
Name
A unique name that describes this device.
Port
The port to use when connecting to this device.
PrivilageLevel
Sets the enable mode privilege level.
RequireVTYLogin
Does connecting to the device require password only validation?
SerialNumber
The serial number for the device.
SerialOther
Additional serial number information.
SNMPRead
SNMP Read community name.
SNMPWrite
SNMP Write community name.
SSHPassword
The SSH password required for SSH connections to this device.
SSHUsername
The SSH username required for SSH connections to this device.
TypeID
The id of the device-type eg 10
TypeOfDevice
The name of the device-type.
For example: Cisco.Router.General
VTYPassword
The password to use if your device verifies using a password only to log in.
VTYPrompt
What does a password request look like from your device.
Example code: Add, edit, or delete entries in a database
The following sample Visual Basic code showing you how to use the Device object of the CatTools API to add, edit or delete an entry in the database.
Add an entry to a database
Dim DB As CatToolsAPI.Database
Dim Device As CatToolsAPI.Device
Set DB = New CatToolsAPI.Database
If DB.OpenConnection Then
	Set Device = DB.Devices.AddNew("Cisco.Router.General")
	If Not Device Is Nothing Then
		Device.Name = "My Device 01"
		Device.HostAddress = "192.168.1.1"
		Device.Group = "My Test Group"
		Device.RequireVTYLogin = True
		Device.VTYPass = "My Password"
		Device.ConnectionMethod = "Telnet"
		If DB.Devices.SaveDevice(Device) Then
			Debug.Print Device.Name & " saved to the database OK."
		Else
			Debug.Print "Adding " & Device.Name & " failed: " & DB.ErrDescription
		End If
	Else
		Debug.Print "Creation of a new device failed: " & DB.ErrDescription
	End If
Else
	Debug.Print "DB connection failed: " & DB.ErrDescription
End If
Set Device = Nothing
Set DB = Nothing
Edit an entry in a database
Dim Devices As CatToolsAPI.Devices
	Set Devices = DB.Devices
	Set Device = Devices.GetByName("My Device 01")
		Debug.Print Device.Name & " Loaded OK"
		Device.AAAPassword = "My New Password "
		If Devices.SaveDevice(Device) Then
			Debug.Print Device.Name & " saved OK"
		Else
			Debug.Print Device.Name & " NOT saved: " & DB.ErrDescription
		End If
	Else
		Debug.Print "Device not found"
	End If
Else
End If
Set Devices = Nothing
Set DB = Nothing
Delete an entry from a database
	If DB.Devices.DeleteByName("My Device 01") Then
		Debug.Print "Deleted OK"
	Else
		Debug.Print "Delete failed: " & DB.ErrDescription
	End If
Else
End If
Set DB = Nothing
