Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools API: Devices class
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Devices class is used to enumerate CatTools Device objects and to enact changes to a Device, such as add, edit and delete.
Properties
Count
Returns the number of devices in your database.
Methods
AddNew
Returns a Device. This Device can then have its settings modified before being saved to the database.
  • Takes as a property the name of the device-type that you would like to create.
DeleteByDevice
Deletes a device from the database.
  • Takes a device object as a parameter.
DeleteByName Deletes a device from the database using the devices name as an identifier.
GetByName
Returns a Device object.
  • Takes the devices name as a parameter.
Items
The collection of Device objects.
Refresh
Resynchronize with the database.
SaveDevice
Saves a Device object to the database.
  • Takes the Device to be saved as a parameter.
Example code: Device iterations
The following sample Visual Basic code showing you how to iterate devices using the CatTools API.
Dim DB As CatToolsAPI.Database
Dim Devices As CatToolsAPI.Devices
Dim Device As CatToolsAPI.Device
Set DB = New CatToolsAPI.Database
DB.OpenConnection
If DB.Connected Then
	Set Devices = DB.Devices
	Debug.Print Devices.Count & " devices in the database"
	For Each Device In Devices
		If Device.Group = "Default" then
			Debug.Print Device.Name & " " & Device.HostAddress
		End If
		DoEvents
	Next
Else
	Debug.Print "Connection failed: " & DB.ErrDescription
End If
DB.CloseConnection
Set Device = Nothing
Set Devices = Nothing
Set DB = Nothing
