Upgrade the agents
To take advantage of new enhancements such as Java Runtime Environment (JRE) and infrastructure updates, be sure to upgrade the SEM agents.
If you selected the Enable Global Automatic Updates check box when you adjusted your Global Automatic Update setting, your SEM agents will update automatically. If you did not enable global automatic updates, you can manually upgrade the SEM agents by accessing the installer through the SEM Console or using an installer downloaded directly from the SolarWinds Customer Portal.
After you upgrade the SEM agents, adjust the Agent Updates setting.
Upgrade SEM agents for Windows using the SEM Console
If your console is connected to the Internet, you can update your SEM agents through the SEM Console.
- Log in to SEM as an administrator.
- On the SEM Console toolbar, click Configure > Nodes.
- On the Nodes toolbar, click Add agent node.
Select the appropriate installation type.
Select Remote Installation to push SEM agents to Microsoft Windows hosts across your network.
Select Local Installation to log in to the device and install the SEM agent.
- Copy the
setup.exefile to the local hard drive on the computer.The security settings in some Windows operating systems require the installer to be on the local hard drive prior to the launch.
- Right-click the installer, select Run as Administrator, and then complete the installation wizard.
Upgrade SEM agents for Windows using an installer
If your console is not connected to the Internet, you can update your SEM agents by downloading the agent installer from another computer with an Internet connection.
Install your new SEM agents in the same folder as your existing SEM agents. This process allows the installer to update the SEM agent software while maintaining all other configuration settings.
- Download the agent installer from the Additional Components page on the SolarWinds Customer Portal.
- Extract the ZIP file contents to your desktop or another location.
- Copy the
SolarWinds-SEM-202X.X-Agent-WindowsInstaller.exefile to the local hard drive on the computer.The security settings in some Windows operating systems require the installer to be on the local hard drive prior to the launch.
- Right-click
setup.exe, select Run as Administrator, and then complete the installation wizard.
Upgrade SEM agents manually
For AIX, HPUX and Solaris, agent installers are not shipped with OpenJDK. As a prerequisite, install Java by performing the following steps:
Upgrade your Java installation to the latest version (Java 11 or equivalent). See the system requirements for the supported versions.
Upgrade the SEM agents using the latest custom Java installer.
After you install and configure a SEM agent on an HP-UX server, the agent may not run as expected.
