Documentation forServer & Application Monitor
Monitoring your applications and environment is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Server & Application Monitor (SAM) is also available in a standalone module.
Volume Capacity Forecast
This widget predicts when the volume will trend into both the Warning range and Critical range.
The columns for this widget are defined as follows:
  • Resource: Lists the resource that is being monitored
  • Last 7 Days: Graphically and numerically displays the capacity trend for the listed resource for the last seven days.
  • Warning: Displays the percentage and time remaining for the Warning threshold to be breached.
  • Critical: Displays the percentage and time remaining for the Critical threshold to be breached.
  • At Capacity: Displays the percentage and time remaining for the listed resource to be at capacity.
Paging controls are located at the bottom of the widget, allowing you to navigate through all data available for this widget. Respectively, the controls are: Fist Page, Previous Page, Page Number, Next Page, and Last Page. You can also specify the number of items to show on the widget or Show All.
