Documentation forServer & Application Monitor
Monitoring your applications and environment is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Server & Application Monitor (SAM) is also available in a standalone module.
Top XX Processes by Physical Memory
The Top XX Processes by Physical Memory widget provides a customizable top list of monitors listed by highest physical memory usage on this node. Only Windows service and process monitors return physical memory values.
This widget is used throughout SAM views:
  • On the SolarWinds Platform Application Summary page, it displays the top physical memory consuming processes taking place within your entire environment.
  • On on the Node Details view, it displays to top memory consuming physical processes specific to application(s) running on the node.
Percentage color thresholds are defined as follows:
  • Green from 0% to 79%
  • Yellow from 80% to 89%
  • Red from 90% to 100%
You can manage the widget through the following:
  • Click the monitor name to navigate to the SolarWinds SAM Monitor Details page.
  • Click the application name to navigate to the SolarWinds SAM Application Details view.
  • Click the network node name to navigate to the Node Details view.
  • Click Edit to change the title, the subtitle, the maximum number of monitors to display, and the filter.
Removing XX from the title removes dynamic inclusion of the defined maximum number of monitors from the widget title.
