Top 10 Monitored Processes by I/O Writes/Sec
This widget displays the total number of I/O Write operations per second.
Fields:
- Process Name: Displays the name of the listed process. Clicking a process in the list takes you to the Component Details page for that process.
- Application Name: Displays the name of the listed application that contains the listed process. Clicking an application in the list takes you to the Application Details view for that application.
- Network Node: Displays the name of the listed node that contains the listed application and process. Clicking a node in the list takes you to the Node Details view for that node.
- IO Writes: Displays the current rate of Input/Output writes.
Clicking Edit lets you to change the Title, Sub-Title, and Maximum Number of Monitors to Display.
Hovering the mouse over any part of this widget will reveal a tooltip with detailed information about the item listed.
