Documentation forServer & Application Monitor
Monitoring your applications and environment is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Server & Application Monitor (SAM) is also available in a standalone module.
Top 10 Monitored Processes by I/O Total Operations/Sec
This widget displays the total number of I/O operations per second.
Fields:
  • Process Name: Displays the name of the listed process. Clicking a process in the list takes you to the Component Details page for that process.
  • Application Name: Displays the name of the listed application that contains the listed process. Clicking an application in the list takes you to the Application Details view for that application.
  • Network Node: Displays the name of the listed node that contains the listed application and process. Clicking a node in the list takes you to the Node Details view for that node.
  • Total IOPS: Displays the current rate of Input/Output.
Clicking Edit lets you to change the Title, Sub-Title, and Maximum Number of Monitors to Display.
Hovering the mouse over any part of this widget will reveal a tooltip with detailed information about the item listed.
