Top XX Components by Statistic Data
The Top XX Components by Statistic Data widget provides a customizable top list of component monitors, listed by statistic value.
- Click the component monitor name to navigate to the SolarWinds SAM Monitor Details page
- Click the application name to navigate to the SolarWinds SAM Application Details view
- Click the node name to navigate to the Node Details view
- Click Edit to change the title, the subtitle, the number of monitors to display, and the filter.
Removing XX from the title removes dynamic inclusion of the defined maximum number of monitors from the widget title.
To get the most use out of this widget, use the filter to display data from specific sources. For example, you can create a widget that displays statistics only from Exchange Server monitors.
