Documentation forServer & Application Monitor
Monitoring your applications and environment is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Server & Application Monitor (SAM) is also available in a standalone module.
Top XX Capacity Problems
This widget displays the top nodes with capacity problems. Clicking a node in the list will take you to the Node Details page for that node. Clicking an objec tin the list will take you to the Details page for that object. When an object's capacity breaches the Warning threshold, the background of the warning value will become yellow. When an object's capacity breaches the Critical threshold, the background of the critical value will become red.
The columns for this widget are defined as follows:
  • Node: Lists the node that is being monitored with its colored icon indicating its current status.
  • Detail: Lists the object with the capacity problem.
  • Warning: Displays the time remaining for the Warning threshold to be breached.
  • Critical: Displays the time remaining for the Critical threshold to be breached.
  • At Capacity: Displays the time remaining for the listed object to be at capacity.
