Node Resource Capacity Forecast
The widget predicts when the node will trend into both the Warning range and Critical range.
The columns for this widget are defined as follows:
- Resource: Lists the resource that is being monitored
- Last 7 Days: Graphically and numerically displays the capacity trend for the listed resource for the last seven days.
- Warning: Displays the percentage remaining for the Warning threshold to be breached.
- Critical: Displays the percentage remaining for the Critical threshold to be breached.
- At Capacity: Displays the percentage remaining for the listed resource to be at capacity.
