Documentation forServer & Application Monitor
Multi Component Statistics - Linear Gauges
If added to a SolarWinds SAM Application Details Summary page, this widget shows linear gauges from multiple statistic sources, allowing you to compare values from different sources.
  • Click Edit to select components and to configure the linear gauges.
Title
Title of the widget.
Subtitle
Subtitle of the widget.
Statistic Data Label
An annotation appended to the statistic value to assist with identifying the units. Data labels appear outside the gauges. For example: bits/s.
Select Components
Select the components to display as gauges.
Select Gauge Type
Selects the component statistic to use as the data source.
Max Scale
Sets the maximum formatted value that can be depicted by the gauge.
Divisor
Formats the statistic value by dividing the raw data by a divisor. For example: a divisor of 8 to convert bits to bytes.
Unit Label
Unit labels appear inside the gauges. For example: bits/s.
Select Style for Gauges
Select the linear gauge graphic.
Gauge Size 30% to 250%
