Min/Max/Average Packets In/Out
The Min/Max/Average Packets In/Out chart is located the Interface Details page. This chart lets you see the total number of packets per second that was both transmitted and received. It also shows the values for the lowest number, highest number, and average number where this data is concerned.
This chart is interactive. Hovering over any part of the chart will provide detailed information. You can check or uncheck any box in the legend to add or remove that element from the chart.
Zooming
You can have the chart show a predetermined time period of data by clicking on any one of the three Zoom buttons; 1 hour, 12 hours, or 24 hours. Alternatively, you can have the chart show a specific time range by dragging the mouse over a small area of the chart, or by adjusting the sliders, also highlighted.
Once you have a time period selected, the lower chart will zoom to the starting and ending values of the selected time period. With the lower chart you can zoom in further by fine tuning the view with the sliders, highlighted above. The main view of the chart will display the selected time period between the two sliders of the lower chart.
Note: The Export button will allow you to export this data to both MS Excel and HTML.
