Documentation forServer & Application Monitor
Edit an assigned application monitor
You can override the template inheritance relationship by editing the components of an assigned Application Monitor. Any modifications you make to an application’s components or component properties are independent from the template. New components that you add to the application are not governed by the original template used to create the application. Modified component properties override the original template settings.
You may need to log in with an administrator account to perform this action.
  1. In the SolarWinds Platform Web Console, click Settings > All Settings > SAM Settings > Manage Application Monitors.
  2. Click the group containing the application you want to edit.
  3. Check the application you want to edit, and then click Edit Properties.
  4. Click Override Template for each polling setting and specify the new value.
  5. Expand the component you want to modify, and then click Override Template and specify new values.
  6. To add components unique to this specific application, click Add Component Monitor then click Submit to apply your changes.
You can select multiple component monitors of the same type to be added by entering a number in the field next to the check box for the component monitor and then checking the check box.
