What will trigger an outage in Pingdom?
One of our most read articles is "Why does Pingdom say my website is down when it's not?" and it does a great job of explaining how Pingdom uptime checks work and why they alert you.
This is just meant as a simple overview of what types of errors a Pingdom Uptime check will detect and mark as an outage. Generally you can say that any site or server that doesn't respond with a HTTP 200 OK or message that everything is good will throw an error in Pingdom.
This data is exactly what our probe servers will report in case they notice an error.
Check Type |
Short Description |
Detailed Description |
HTTP |
Timeout (> 30s) |
The page took too long to load and timed out |
HTTP |
HTTP Error 400 |
HTTP Server Error 400 Bad Request |
HTTP |
HTTP Error 401 |
HTTP Server Error 401 Unauthorized |
HTTP |
HTTP Error 403 |
HTTP Server Error 403 Forbidden |
HTTP |
HTTP Error 404 |
HTTP Server Error 404 Not Found |
HTTP |
HTTP Error 405 |
HTTP Server Error 405 Method Not Allowed |
HTTP |
HTTP Error 406 |
HTTP Server Error 406 Not Acceptable |
HTTP |
HTTP Error 407 |
HTTP Server Error 407 Proxy Authentication Required |
HTTP |
HTTP Error 408 |
HTTP Server Error 408 Request Timeout |
HTTP |
HTTP Error 500 |
HTTP Server Error 500 Internal Server Error |
HTTP |
HTTP Error 502 |
HTTP Server Error 502 Bad Gateway |
HTTP |
HTTP Error 503 |
HTTP Server Error 503 Service Unavailable |
HTTP |
HTTP Error 504 |
HTTP Server Error 504 Gateway Timeout |
HTTP |
HTTP Error 505 |
HTTP Server Error 505 HTTP Version Not Supported |
HTTP |
No data from server |
No data received from server |
HTTP |
Required string missing |
The required string was not found |
HTTP |
Invalid HTTP response |
Invalid HTTP response received from server |
HTTP |
Too many redirections |
Maximum redirection depth reached |
HTTP |
Infinite redirection loop |
Redirection creates an infinite loop |
HTTP |
SSL connection error |
Cannot make SSL connection - Error on receive |
HTTP |
Timeout (> 30s) |
Socket timeout, unable to connect to server |
HTTP |
Connection refused |
Connection refused by server |
HTTP |
Unknown target |
The URL is invalid or the server was not found |
HTTP |
Network error |
Network is unreachable |
HTTP |
Network error |
No route to host |
HTTP |
DNS error |
Temporary failure in name resolution |
HTTP |
Connection reset |
Connection reset by peer |
HTTP |
DNS error |
Non-recoverable failure in name resolution |
HTTP |
Unknown target |
HTTP |
Unknown error |
Unknown internal error |
HTTP |
Redirection error |
Could not find redirect location |
HTTP |
Cannot make SSL connection - No data received from server |
HTTP |
Connection reset |
Error on receive |
HTTP |
Forbidden string found |
The string that should not exist on the page was found |
HTTP |
HTTP Error 413 |
HTTP Server Error 413 Request Entity Too Large |
HTTP |
HTTP Error 507 |
HTTP Server Error 507 Unexpected error |
HTTP |
HTTP Error 520 |
HTTP Error 520 |
HTTP Custom |
Status not OK |
The status in the XML file was something other than OK |
HTTP Custom |
Unable to load XML file |
The XML file could not be loaded |
HTTP Custom |
Invalid XML format |
The XML file was not correctly formatted |
HTTP Custom |
HTTP Custom |
HTTP Custom |
No status in XML file |
No status was defined in the XML file |
HTTP Custom |
No response time in XML file |
No response time was defined in the XML file |
HTTP Custom |
Incorrect response time format |
The response time in the XML file was not a number |
IMAP |
Timeout |
Force timeout |
IMAP |
Timeout |
Socket timeout |
IMAP |
Unknown target |
Invalid hostname, address or socket |
IMAP |
Expected string missing |
The expected string was not found |
IMAP |
Cannot make SSL connection |
IMAP |
IMAP |
No route to host |
No route to host |
Ping |
Timeout |
Forced timeout |
Ping |
Packet loss |
Packet loss occured |
Ping |
Unknown target |
Invalid hostname/address |
Ping |
Timeout |
Time to live exceeded |
Ping |
Network error |
Host Unreachable |
Ping |
Network error |
Network Unreachable |
Ping |
Unknown error |
Ping |
Timeout |
Ping timed out |
Ping |
Network error |
Host not found |
Ping |
Network error |
Multiple hosts responded |
Ping |
Unknown error |
Ping |
Timeout |
Ping timed out |
Ping |
Network error |
Port unreachable |
Ping |
Unknown error |
POP3 |
Timeout |
Force timeout |
POP3 |
Timeout |
Socket timeout |
POP3 |
Unknown target |
POP3 |
POP3 |
POP3 |
POP3 |
No route to host |
No route to host |
POP3 |
No data received from host |
SMTP |
Timeout |
Force timeout |
SMTP |
Timeout |
Socket timeout |
SMTP |
Unknown target |
SMTP |
Authentication not supported |
SMTP |
Authentication failed |
SMTP |
SMTP |
TLS not supported |
Target server does not support TLS |
SMTP |
SMTP |
No route to host |
No route to host |
SMTP |
SMTP |
Service not known |
Name or service not known |
TCP Port |
Timeout (> 30s) |
The connection took too long to establish |
TCP Port |
Unknown target |
TCP Port |
Connection refused by host |
TCP Port |
Timeout (> 30s) |
Socket timeout |
TCP Port |
Network error |
No route to host |
TCP Port |
Network error |
TCP Port |
Unknown target |
TCP Port |
Unknown target |
Servername was not provided or unknown |
TCP Port |
DNS error |
TCP Port |
Connection reset |
TCP Port |
Invalid response |
Unexpected response from host/socket |
UDP |
Timeout (> 30s) |
Forced timeout |
UDP |
Unknown target |
UDP |
Invalid response |
UDP |
Timeout (> 30s) |
Socket timeout |
UDP |
DNS |
Timeout |
Force timeout |
DNS |
Timeout |
Socket timeout |
DNS |
Expected IP not found |
DNS |
Unknown target |
Invalid hostname |
DNS |
Domain not found |
Domain not found by the nameserver |
DNS |
No IP address returned |
The queried DNS server did not return an IP address |
Navigation Notice: When the APM Integrated Experience is enabled, Pingdom shares a common navigation and enhanced feature set with other integrated experience products. How you navigate Pingdom and access its features may vary from these instructions.
