Use Integrated Remote Desktop in the SolarWinds Platform
This topic applies to all SolarWinds Platform products.
This information is deprecated and only relevant for versions that have already reached end of life. See End of Life Policy for details.
This feature requires Internet Explorer 9 and earlier.
Sometimes it is necessary to console into a remote server to troubleshoot an issue. This can be accomplished within the SolarWinds Platform Web Console.
To enable this feature:
  1. In the SolarWinds Platform Web Console, select Settings > All Settings and click Manage Accounts under User Accounts.
  2. Select your Orion account and click Edit.
  3. Under the ALERTS section, select Yes for Allow Browser Integration.
  4. Click Submit.
The Node Details page will have an extra set of icons in the upper right, including one that links to the Remote Desktop page.
Press Ctrl+Alt+Break to enter/exit full screen mode.
  1. Open the Node Details view for the server you want to view remotely.
    The easiest way to open the Node Details view is to click the remote server you want to view in any All Nodes resource.
  2. Click , located at the of the Node Details view.
    Depending on the security settings of your browser, you may be asked to install an ActiveX control for remote desktop viewing. Follow all prompts to install this required control.
  3. Verify the Server IP address or hostname, select an appropriate Screen Size, and then click Connect.
