Use Orion Web Console breadcrumbs in the Orion Platform
This topic applies to all Orion Platform products.
As you navigate Orion Web Console views, you can use breadcrumbs to the pick other views that are on the same or higher navigational level as your current view.
- You cannot view breadcrumbs in wizards, dashboards, or full-page resources such as All Active Alerts.
- Only the first 50 monitored nodes, listed in alphanumeric order by IP address, are displayed.
- Click a breadcrumb to open the view.
- Click > next to a breadcrumb to open a clickable list of all views at the same navigation level. For example, if you are on a Node Details view, clicking > displays a list of other monitored nodes.
Customize breadcrumbs
- Click > at an appropriate level in the breadcrumbs to open the drop-down.
- Click Customize This List.
- Select an option from the menu, and click Submit.
All items in the customized list will be identical for the selected criterion.
