Top XX Transactions
NAM — NPM
This widget lists a specified number of monitored applications by average number of transactions per minute, from highest to lowest, over a specified period of time. The chart displays the number of transaction for selected applications over time. Graphed lines match the colors assigned to listed applications.
See Monitor Quality of Experience metrics for more details.
Customize the widget
- Click Edit.
- Edit the chart Title and Subtitle, as appropriate.
- Select the Number of Items you want to display.
- Select appropriate options from the following drop-down lists to customize the list of monitored applications:
- Group by
- Category
- Risk Level
- Productivity Rating
- Select appropriate values for the Default zoom range, Amount of historical data to load, and Sample interval.
- Click Submit to commit customizations.
Export or print
- Click Export.
- Customize the chart to format it for export, as follows:
- Edit the chart Title and Subtitle, as appropriate, in the Chart Titles section.
- Select appropriate values for the Default zoom range, Time Period, and Sample Interval.
- Resize the chart by selecting appropriate Width (pixels) and Height (pixels).
To maintain the same aspect ratio, enter
0for the Height and vary the Width, as needed. - Click Refresh to review customizations.
- Select the appropriate option on the Custom Chart view:
- Click Printable Version in the top right.
- Click Export to XLS in the Display Chart Data section.
- Click Export to HTML in the Display Chart Data section.
