Configure Group Managed Service Account (gMSA) for polling AppInsight Applications and Components
SolarWinds Observability Self-Hosted and SolarWinds Server & Application Monitor (SAM) supports the use of Group Managed Service Accounts (gMSA) to enhance security and simplify credential management for monitoring services.
Supported entities
  • AppInsight for IIS
  • AppInsight for Active Directory
  • AppInsight for SQL
Component types
  • Custom Performance Counter Monitor
  • Custom PowerShell Monitor
  • Custom WMI Monitor
  • HTTP Monitor
  • LDAP Monitor
  • Log Parsing Monitor
  • Performance Counter Monitor
  • Process Monitor - Windows
  • SQL Table Monitor
  • Windows Event Log Monitoring
  • Windows Service Monitor
Configure gMSA for AppInsight applications and components
Configure AD environment with Kerberos
See Configure Kerberos for WMI/WinRM authentication in the SolarWinds Platform.
Configure the SAM module to use Kerberos
  1. Open the File Explorer and go to the Orion Installation Folder.
  2. Open the <OrionFolder>\SolarWinds.APM.Probes.dll.config and <OrionFolder>\Web\bin\SolarWinds.APM.Probes.dll.config file.
    Default location: C:\Program Files\SolarWinds\Orion
  3. Change in both files WMIAuthenticationMode property in both files to KerberosStrict/KerberosPreferred/Default.
  4. Restart SolarWinds Platform services.
Configure SAM Applications to use Kerberos:
Some applications have the Authentication method in Settings to make Kerberos work. Select the Kerberos option at the dropdown
Create group Managed Service Accounts
Requirements
  • Forest schema is Windows Server 2012 or later
  • KDS root key for Active Directory deployed
  • At least one Windows Server 2012 or later domain controller in the domain where you want to create a gMSA
    For details, see Create the Key Distribution Services KDS Root Key | Microsoft Learn in Microsoft documentation.
  • Membership in Domain Admins or the ability to create msDS-GroupManagedServiceAccount objects
To create a gMSA using PowerShell, follow these steps:
  1. On the domain controller, run Windows PowerShell.
  2. At the command prompt for the Windows PowerShell, type the following commands, and then press ENTER. (The Active Directory module loads automatically.)
     New-ADServiceAccount [-Name] <string> -DNSHostName <string> [-KerberosEncryptionType <ADKerberosEncryptionType>] [-ManagedPasswordIntervalInDays <Nullable[Int32]>] [-PrincipalsAllowedToRetrieveManagedPassword <ADPrincipal[]>] [-SamAccountName <string>] [-ServicePrincipalNames <string[]>]
Example of the command:
New-ADServiceAccount -Name "MyGMSAtest$" -DNSHostName "testRoot.local" -PrincipalsAllowedToRetrieveManagedPassword @("PCName1$", "PCName2$") -KerberosEncryptionType AES128,AES256,RC4
For details, see Create Group Managed Service Accounts in Microsoft documentation.
Configure Kerberos delegation
To make gMSA identity work with a service, enable the delegation of credentials for the service. Configure each controller and computer on the domain controller to trust this computer for delegation to specified services only (Use Kerberos Only). See Configuring Kerberos delegation for group Managed Service Accounts in Microsoft documentation.
Step 6: Configure Log On Permission
To allow the gMSA account to authenticate and run services properly, add the gMSA accounts to the following policies on domain controllers and monitored computers.
Target Machine Configuration
Admin User
To configure permissions to access WMI-related namespaces, run the following script:
Set-PSSessionConfiguration -Name Microsoft.PowerShell -ShowSecurityDescriptorUI -Force
 # Add the gMSA to a group with CIM permissions
 $GMSA = "<domain>\<username>$"
 $Group = "Administrators"
 Add-LocalGroupMember -Group $Group -Member $GMSA
Non-Admin User
For non-admin users, complete these steps:
  1. Run the following script :
    # Minimum required
    Add-LocalGroupMember -Group "Remote Management Users" -Member $GMSA
    Add-LocalGroupMember -Group "Performance Monitor Users" -Member $GMSA
  2. Run the following script which will open permission menu:
    winrm configSDDL default
    Add the <username>$ that was created earlier, and configure permissions. Check “Allow” for Read(Get,Enumerate,Subscribe) and Execute(Invoke), and if you need modules that modify, check Write(Put,Delete,Create).
  3. Run the following script that will open WmiMgmt menu:
    wmimgmt
    1. Right click on WMI Control (Local) and go to Properties.
    2. Go to Security tab and click on “Security“ button that will open Security for Root menu.
    3. Add “Remote Management Users” group and click on Advanced button.
    4. In new dialog select “Remote Management Users” and click Edit.
    5. In the Applies to dropdown select 'This namespace and subnamespaces'.
    6. In the Permissions section check the following boxes:
      • Execute Methods
      • Enable Account
      • Remote Enable
    7. Click OK to save.
  4. Run the following script:
    $rmSid = (New-Object System.Security.Principal.NTAccount("BUILTIN","Remote Management Users")).Translate([System.Security.Principal.SecurityIdentifier]).Value
    $currentSDDL = (Get-Item WSMan:\localhost\Service\RootSDDL).Value
    $newSDDL = $currentSDDL -replace "D:P", "D:P(A;;GR;;;$rmSid)"
    Set-Item WSMan:\localhost\Service\RootSDDL -Value $newSDDL -Force
    Restart-Service WinRM
Domain Machine Configuration
To connect thedomain controller using gMSA, assign gMSA user to domain-level group. Run the following script.
$GMSA = "MyGMSAtest$"
$Group = "Administrators" # Domain Administrators Group
Add-ADGroupMember -Identity $Group -Members $GMSA
Configure AppInsight for SQL with gMSA
To configure AppInsight for SQL with gMSA, follow these steps:
  1. Add the gMSA user to SQL Server Management Studio (SSMS) with proper privileges (db_owner right).
  2. Use the default SQL Server port (1433) for connectivity.
  3. Install Microsoft Kerberos Configuration Manager on the domain controller for SPN configuration.
    Use the hostname to connect.
    If errors occur, you can manually setup SPN using one of the following options:
    • MSSQLSvc/<hostname>:1433
    • MSSQLSvc/<hostname>.<domain name>:1433
    Example: MSSQLSvc/AUS-OOO-56445.testRoot.local:1433
  4. Ensure that our SQL Server instance is running. See Determine Whether the Database Engine is Installed and Started in Microsoft documentation.
  5. Set your gMSA account as the Log On account in the SQL Server Configuration Manager. See Change the SQL Server service startup account in Microsoft documentation.
  6. Enable TCP/IP for SQL Server in the SQL Server Configuration Manager. See Use SQL Server Configuration Manager in Microsoft documentation.
  7. Match the Connection String to the SPN: Verify that your Service Principal Name (SPN) matches the connection string.
