Data Volume By Node
NAM — NPM
The Data Volume widget displays the total amount of traffic monitored on the viewed node over time.
See Monitor Quality of Experience metrics for more details.
Customize the widget
- Click Edit.
- Edit the chart Title and Subtitle, as appropriate.
- Select appropriate values for the Default zoom range, Amount of historical data to load, and Sample interval.
- Click Submit to commit customizations.
Export or print
- Click Export.
- Customize the chart to format it for export, as follows:
- Edit the chart Title and Subtitle, as appropriate, in the Chart Titles section.
- Select appropriate values for the Default zoom range, Time Period, and Sample Interval.
- Resize the chart by selecting appropriate Width (pixels) and Height (pixels).
To maintain the same aspect ratio, enter
0for the Height and vary the Width, as needed. - Click Refresh to review customizations.
- Select the appropriate option on the Custom Chart view:
- Click Printable Version in the top right.
- Click Export to XLS in the Display Chart Data section.
- Click Export to HTML in the Display Chart Data section.
