Change the SolarWinds Platform Web Console color scheme in the SolarWinds Platform
This topic applies to all SolarWinds Platform products.
There are multiple options how you can adjust the color scheme in the web console.
For the best accessibility experience, use the light theme.
Dark theme for modern dashboards
You can configure the theme for modern dashboards in your user profile.
In SolarWinds Platform Web Console, click the user icon in the top-right corner.
Select Profile.
In the Account theme list, select the mode to be used.
Select System if you want the web console to follow your system settings.
The web console color changes according to your selection. The color theme is only applicable to modern dashboards.
Widget headers
To change the color for widget headers, complete the following:
- Click Settings > All Settings in the menu bar.
- In the Customize Navigation & Look grouping, click Color Scheme.
- Select a color scheme, and click Submit.
