Add a Page Speed check
- In SolarWinds Observability SaaS, click Add Data at the top.
In the Add Data dialog Intro, click Monitor my website.
Click Page Speed.
Enter a name for the check and the URL that you want to test.
The URL should be formatted with the desired protocol http or https, for example: https://example.com. If you do not specify a protocol, SolarWinds Observability will automatically add https. -
Click Add Tags to add any tags to your Page Speed check. Enter a tag key and value, and then click Add Tag. Repeat this step as necessary for any tags you want to add. Click Next.
The Add tags step is optional.
Select a location category to test from: Regions, Countries, or Cities.
Select the Page Speed check location(s). Click Next.
If applicable, you can select more than one location. For example, if you selected to test from Cities, you can select both Boston and Los Angeles locations. Each location selected will increase your checks count.
Review all of the Page Speed check settings. Click Add Add Page Speed.
