Add Cisco ACI devices
Add Cisco ACI devices to SolarWinds Observability to start monitoring the health, performance, and statistics.
Requirements
Network Collector 2025.4 or later
In SolarWinds Observability SaaS, click Add Data at the top.
In the Add Data dialog, click the Network tab and click Cisco ACI devices.
Select an existing network collector or deploy a new one.
On Define Device, specify the network device you want to monitor in SolarWinds Observability SaaS and click Next.
Provide the hostname or IP address.
If the device has a dynamic IP address, select Dynamic IP Address. This option requires a complete IP-hostname pair for successful lookup.
Optional settings
- To identify the device in SolarWinds Observability SaaS, specify a display name.
- To add a custom tag to the device, click Add Tag and specify the key and the value for the tag. You can also add tags to the device later on the device details page under the Overview tab.
Select how you want to poll the network device.
Select ICMP to monitor the device health by comparing the polled results to predefined threshold values. ICMP polls device status, average response time, or packet loss percentage.
Select SNMPv2 to get more details by querying the management information base and performance indicators tied to specific object identifiers.
Provide ACI Credentials and click Next to continue. Before you can continue, the SSL certificate is checked. If validating the SSL certificate fails, you will be informed about it.
To use new credentials, specify the display name, username, and password. The display name helps identify the credentials set for reuse.
To use existing credentials, select Existing, and choose a credentials set from the drop-down list.
If you selected SNMP, select metrics and resources to be monitored on the devices and click Next. For example, you can monitor status and response time, topology, and selected interfaces.
On Summary, review the information and click Submit.
The Cisco ACI device is added for monitoring.
