View traffic for a designated IP address
- Click My Dashboards > NetFlow > NTA Summary.
- Click Flow Navigator on the left edge of the view. The Flow Navigator is available on any default NTA view.
- Under View Type, select Detail.
- Select a Detail View Type, and then select from the type-specific list.
- Select the Time Period from which you want to view traffic data.
- Select a Flow Direction. For the Node Details view, this selection is automatically converted to Ingress.
- Select Endpoints, enter an IP address, and click Add Filter.
If you want a filtered view of a subnet, type the appropriate range of IP addresses here, either as a range (
192.168.1.0-192.168.1.255) or using the CIDR notation (192.168.1.0/24). - Click Submit.
