Documentation forNetFlow Traffic Analyzer
Node or Interface filtered view
Using the Flow Navigator, you can customize a filter that will allow you display the traffic connected with a specified node or interface according to your needs.
  1. Click My Dashboards > NetFlow > NTA Summary.
  2. Click Flow Navigator on the left edge of the summary view. The Flow Navigator is available on any default NTA view.
  3. Specify the View Type:
    1. Click Detail and, then select Node or Interface.
    2. Define a node.
      If you select a node here, you can specify only Ingress or Egress for the Flow direction. Selecting Both results in applying the flow direction default for the appropriate view.
    3. If you are specifying an interface filtered view, define an interface.
  4. Select the Time Period over which you want to view network traffic connected with the selected node or interface.
  5. Select a Flow Direction.
  6. You can also further limit the view by including or excluding some of the following items:
  7. Click Submit.
  8. If you want to save your custom filtered view for future reference, click Save Filtered View to Menu Bar.
