Documentation forNetFlow Traffic Analyzer
Node Interfaces
The Node Interfaces widget provides a list of the interfaces present on the viewed node.
The Node Interfaces table provides the following information for each listed interface:
  • A status icon
  • A device type icon
  • The interface name
  • The amount of data traffic, in both bytes and packets, transmitted into the viewed node on the selected interface over the selected period of time
  • The amount of data traffic, in both bytes and packets, transmitted out of the viewed node on the selected interface over the selected period of time
Edit the widget
  1. Click Edit in the widget header.
  2. Edit the following attributes:
    • Title reflects the name of the widget.
    • Subtitle is an optional field you can use to further define your widget.
  3. Click Submit.
NetFlow Traffic Analyzer provides default values for both the Node Interfaces Title and Subtitle. If you edit either field on the Edit Node Interfaces view, you can restore the default values by clearing the respective fields, and then clicking Submit.
To learn more about working with interfaces, see the NPM Administrator Guide.
