Documentation forNetFlow Traffic Analyzer
Cisco Catalyst 3560/3750
Standard 3750 and 3560 switches do not support NetFlow. The 3750-X and 3560-X L3 switches only support NetFlow if they have the C3KX-SM-10G Service module. In this case the only option is using Flexible NetFlow.
Required tasks to create a flexible NetFlow configuration
  1. Enable ingress and egress on the C3KX-SM-10G module uplink ports.
  2. Create and configure the flow record.
  3. Create and configure the flow exporter(s).
  4. Create a flow monitor to bind the flow record to the exporter.
  5. Apply the flow monitor to the appropriate interface on the device.
Configuration example
The following configuration example creates a custom flow record and flow monitor. Each section includes notes that explain what the commands do.
Interface setup
interface TenGigabitEthernet1/1/1
switchport trunk encapsulation dot1q
switchport mode trunk
ip flow monitor NetFlow input
ip flow monitor NetFlow outpu
interface TenGigabitEthernet1/1/2
ip flow monitor NetFlow output
You must enable ingress and egress on the C3KX-SM-10G module uplink ports since they are the only interfaces on the module that support NetFlow export functionality.
Flow record
Flow record NetFlow
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect interface input snmp
collect interface output snmp
collect counter bytes
collect counter packets
The flow record part of this configuration example creates the record called NetFlow and uses the match ipv4, match transport, and collect commands to define the key fields in the record by which flow data will be processed.
Flow exporter
flow exporter NetFlow-to-Orion
destination 10.10.10.10
source vlan254
transport udp 2055
export-protocol netflow-version 9
The flow exporter part of the configuration examples defines the following:
  • An exporter called NetFlow-to-Orion.
  • The destination, which is the IP address of the SolarWinds Platform server, to which flow data will be exported.
  • The source called vlan254, which is the interface with the IP address with which SolarWinds Platform is managing the device, and from which flow data will be exported.
  • The transport protocol (UDP) and port (2055, SolarWinds Platform collection port) through which the flow data will pass.
  • The NetFlow export protocol (NetFlow version 9) that the NetFlow collector should expect and use to process the data.
Flow monitor
flow monitor NetFlow-Monitor
description Original Netflow captures
record ipv4
cache timeout inact 10
cache timeout act 5
ip flow monitor NetFlow-Monitor input
The flow monitor part of the configuration example defines the following:
  • A monitor called NetFlow-Monitor that uses the record and exporter commands to bind the flow record (ipv4) to the flow exporter (NetFlow-to-Orion) you already created.
  • The interface command defines the interface (two of them, in this case) to which the flow monitor NetFlow-Monitor applies.
  • The ip flow monitor command specifies the capture of ingress data (input) on the two specified interfaces.
Full configuration
The overall configuration without annotations looks like this:
    source vlan254
    transport udp 2055
    source vlan254
    transport udp 2055
export-protocol netflow-v5
    record ipv4
cache timeout act 5
