NCM Advanced Settings
The settings you enter under Logging Settings, Cache Settings, and Reports Settings. Connection Profile Settings, EOS Settings are used to track and enhance the actions performed with the software.
To access Session Tracing Settings, choose CLI Settings in the Product Specific Settings group.
Logging Settings
Check each logging event type for which you want the software to log its actions. Logging is most useful in determining the source of an issue with some specific component or action, or to have a record of actions for auditing purposes.
Cache Settings
Click Enable Config and Policy Caches to enable the software to maintain these two caches for quick display of config and policy information.
Reports Settings
Click the sorting option to use in enhancing the display speed of Inventory Reports.
Click to enable this option to enable the software to use a connection profile enabled for auto-detect when an assigned connection profile cannot be used for an NCM operation.
EOS Settings
Click Enable EOS autorun to set the time when the software performs a match of EOS data with NCM managed devices.
