Documentation forNetwork Configuration Manager
Managing network configurations is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. Network Configuration Manager (NCM) is also available in a standalone module.
Overall Running vs. Startup Config Conflicts
This widget provides a pie chart designating the percentage of devices running different configurations than their startup configurations. If the device reboots, the startup config will be used and will not represent the currently running settings on the device. Use this chart to help you locate the devices that need their configurations committed to NVRAM. Click the pie chart to navigate to NCM and review a detailed presentation of which nodes have and have not been backed up. You can change the scope of the pie chart by clicking Edit.
The following time frames are available for the snapshot function:
  • As of Last Update: This flexible time frame is based on the last time an update occurred and any changes made thereafter. An update occurs when you run inventory, download configuration files, or execute a baseline of your network.
  • Last Hour
  • Last 2 Hours
  • Last 24 Hours
  • Today
  • Yesterday
  • Last 7 Days
  • This Month
  • Last Month
  • Last 30 Days
  • Last 3 Months
  • This Year
  • Last 12 Months
  • Custom Option: This option allows you to specify a range.
