HTTPS certificates
HTTPS is enabled by default in KSS NG, using the default KSS NG SSL certificate.
To change SSL, go to Settings > HTTPS certificates > Available Windows certificates.
To display a certificate in KSS NG, you must import it to a subfolder of the Certificates folder.
Bring up the Run command by pushing the Windows key + R. Enter
certmrg.msc, and press Enter. -
Import the certificate to the Trusted root certification authorities folder.
Only certificates with a private key can be used. KSS NG requires authentications from both the client and the server.
