Registry settings - NTServiceSocket
The Kiwi CatTools Manager connects to the service via TCP port 4400. This allows the two applications to communicate. If another process is already using this port, use the Kiwi CatTools registry to change the port value.
| Section (32-bit Windows OS) | HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds\CatTools\Properties
| Section (64-bit Windows OS) | HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SolarWinds\CatTools\Properties
| Value (STRING) | NTServiceSocket |
| Min. value | 1 |
| Max value | 65535 |
| Default value | 4400 |
| Type | TCP port number |
